Lithium Ion batteries
I happen to have a few of those prepaid cell phones handy... they have 3.6V lithium ion
batteries inside and I was wondering if I can put them in series to power a BOE-based robot
project with little to no problems?
I'd just put them back in the cell phones to charge so I figured this would be an easy source
of power for my BOE.
I'd stick with NiMH battery packs.· You still have to be careful of short circuits, but they're less dangerous.
that these have those safeties built in. (I could most likely check)
Do you have any recommendations for where to get cheap, small NiMH packs that'll work without any additional components
on a BOE? Regular AA rechargables are well and good, but I'd like a little longer life per charge.
I'd prefer the 1900mAh and above Lithium cells in a 7.2 volt format that are used in R/C airplanes if they didn't cost $40-60 USD each. NiMH AA cells are nearly up to 3000mAh in some cases, getting closer to alkaline in capacity. MiMH AAA cells are at about 900ma and though I have some I think they are somewhat less useful.
The 3.6 Lithium cell is ideal for a lower voltage operation of the Propeller or the SX without a regulator. You could use your cell phone as the recharger. Just don't expect to suck all the power out of it. They should never be run lower than 1.8 volts [noparse][[/noparse]the SXes can be set to Brown Out above that limit at 2.4 volts].
For hefty motors, I have an 8volt Gel Cell at 9Ah. The 6volts don't work with some regulators and the 12 volts just waste a lot in dumping heat.
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
