idea for method to plug battery pack in for charging.
tedbeau
I am building a robot that will be powered by a 4 cell AA battery pack. Rather than having to remove the battery pack and remove the batterys for recharging, I would prefer to be able to plug a charger into the robot. Can anyone point me to a project like this. I have a standard 4 cell wall charger that I could wire a cable to. Would I just have to solder a lead to the negative and positive·leads and then plug that into an adapter on the robot?
Ted
Ted
Take a look at this
This might work for you, here is the the link
http://www.radioshack.com/product/index.jsp?productId=2062132&cp=2032056.2818124.2818347&parentPage=family
··Thanks for any··that you may have and all of your time finding them
Sam
What I plan to use on my boe-bot, is a recepticle like what's on the Board Of Education, and wire it so the power is shut off to the board when you plug the charger into it, and that would connect the power plug to the battery for charging. If you look at the schematics, they will point out which terminals will do what.
David
There are 10 types of people in this world,...
Those that understand binary numbers, and those that don't!!!
what you are suggesting about wire the battery pack to the charger should work, I'd keep the wires short, and in the effort of keeping you charger useful for other projects, how about building a "dummy" battery that will fit in the charger and make the connection to the bot. or add a Jack to the case of the charger which will connect to the terminal internally, allowing you to plug in a cable to charge your bot.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
dgswaner, I like your idea of a three position switch. I may look into adding one now as I build. If I dont make the recharger, I can still use the center poition as OFF and one position as RUN.
This assumes the batteries are no longer connected to the BOE-Bot, of course.· It probably wouldn't hurt the BOE-Bot to leave them connected, but it would confuse the charger.· The Charger wants to charge batteries, NOT "charge batteries AND run a BOE-Bot" at the same time.
