program "results" of reacton timer on serial lcd
the reaction timer results are given in ms on the 2 button reaction timer, as in pg 99 of parallax manual. does anyone know how to·display the·results·on the lcd(instead of relying on the computer monitor). below is my code for the reaction timer. thanks, jim·:: and below this code i have entered some lcd code that may be approriate. thanks for the efforts...
' {$STAMP BS2}
' {$PBASIC 2.5}
'PIN 3 PLAYER A
'Pin 4 player b
timeCountera···· VAR···· Word· 'player a timescore
timeCounterb· VAR·· Word······ 'player b timescore
DEBUG···· "PRESS BOTH BUTTONS FOR RED LIGHT, AND WAIT FOR GREEN LIGHT.",·· CR,CR,CR
DEBUG········· "WHEN LIGHT TURNS GREEN, RELEASE BUTTON",· CR,
········· "AS FAST AS YOU CAN.", CR, CR
DO········································ 'begin main LOOP
·· DO······································ 'nested loop repeats
·· 'nothing
·· LOOP UNTIL (IN3 = 1) AND (IN4 = 1)········ 'until pushbutton release
·· LOW 14·································· 'bi color led red
·· HIGH 15
·· PAUSE 1000······························· 'delay 1 second
·· HIGH 14·································· 'bi color led green
·· LOW 15
·· timeCountera = 0·························· 'set time counter to 0
·· timecounterb = 0
···· DO······································· 'nested loop count time
······ PAUSE 1
······· IF (IN3 = 1) THEN·············· 'if button is still down
······· timecountera = timecountera + 1·· 'increment counter
···· ENDIF
···· IF (IN4 = 1) THEN
···· timecounterb = timecounterb + 1
···· ENDIF
···· LOOP UNTIL (IN3 = 0) AND (IN4 = 0)· 'until both pushbuttons is released
···· LOW 14··································· 'bi color led off
···· DEBUG· "PATTY'S TIME:"· ,·· DEC timeCountera,· " MS.",CR··· 'display time
···· DEBUG· "JIM'S TIME: ", DEC timecounterb, " MS. ", CR, CR
···· IF (timecountera < timecounterb) THEN
···· DEBUG "WINNER IS PATTY!", CR
···· ELSEIF (timecounterb < timecountera) THEN
···· DEBUG "WINNER IS JIM!", CR
···· ELSE············ 'a and b times are equal
···· DEBUG "YOU 2 KNUCKLEHEADS TIED!", CR
···· ENDIF
···· DEBUG CR
···· DEBUG "TO PLAY AGAIN, TELL JIM HE'S COOL! ", CR,CR,CR,CR
LOOP··········································· 'back to begin main loop
' {$STAMP BS2}
' {$PBASIC 2.5}
'lcd scott ed trial BS2 modified TO work.bs2
i·· CON·· 254
clrlcd·· CON· 1
prn_at·· CON· 136
j·· VAR·· Word
n96n·· CON·· $4054
LOW 0
PAUSE 1000
SEROUT 0,n96n,[noparse][[/noparse]i,clrlcd]
SEROUT 0, n96n, [noparse][[/noparse]"number:"]
FOR j = 0 TO 2000
SEROUT 0,n96n,[noparse][[/noparse]i, prn_at,DEC j, "··· "]
PAUSE 30
NEXT
STOP
' {$STAMP BS2}
' {$PBASIC 2.5}
'PIN 3 PLAYER A
'Pin 4 player b
·· 'nothing
·· HIGH 15
·· LOW 15
·· timecounterb = 0
······ PAUSE 1
···· ENDIF
···· ENDIF
···· ENDIF
···· DEBUG CR
' {$STAMP BS2}
' {$PBASIC 2.5}
i·· CON·· 254
clrlcd·· CON· 1
prn_at·· CON· 136
j·· VAR·· Word
n96n·· CON·· $4054
LOW 0
PAUSE 1000
FOR j = 0 TO 2000
PAUSE 30
NEXT
STOP
If you are using a parallax serial LCD replace your DEBUG commands where you want to display text on a serial LCD with something similar to this as an example.
REPLACE THIS:
WITH THIS:
SEROUT 13, 84, [noparse][[/noparse]"YOU 2",13 "KNUCKLEHEADS"]
SEROUT 13, 84, [noparse][[/noparse]12]: PAUSE 500
SEROUT·13, 84,·[noparse][[/noparse]"TIED!"]
"Connect your parallax serial LCD'S RX line to pin 13"
Go have a look here you will find lots of useful information.
http://www.parallax.com/dl/docs/prod/audiovis/SICSerialLcd.pdf
What if there was nothing? Nothing is something!
Post Edited (beazleybub) : 7/2/2008 7:24:23 AM GMT
