Algorithm Efficiency question — Parallax Forums
Damien AllenDamien Allen Posts: 103
edited 2008-02-23 20:58 in General Discussion
I am completing an assignment and I'm stuck on the final part. I have to write a program in C that will generate a list of random numbers (Floats) and then sort them using the following sorts, Bubble sort, Quick sort, Heap Sort and Bucket Sort whilst keeping track of swaps and comparisons.
I have completed this section sucessfully·but I now need to derive the expected number of swaps and compares for the above sorts, which I haven't a clue where to start.
Can anybody point me in the right direction? I have managed to find information on Bubble sort but nothing else.
  • phil kennyphil kenny Posts: 233
    edited 2008-02-23 18:12
    Google is your friend. Some of your questions may be answered here:
    en.wikipedia.org/wiki/Random_permutation_statistics
    phil
  • Damien AllenDamien Allen Posts: 103
    edited 2008-02-23 20:11
    I'm not sure that is what I need. I need to derive two equations from each sort that will approximate the number of swaps and the number of compares
    edited 2008-02-23 20:53
    Well...
    You may want to check up something called 'Big O' notation...
    http://en.wikipedia.org/wiki/Big_O_notation
    (The most sloppy and inaccurate math, even more inaccurate than a restaurant tab... )
    The formula for calculating the number of calculations of a bubblesort algorithm is O(n2) I think.
    (A while since I had to do this kind of math)
    This means that the number of Operations increases rather fast as the number of entries increases.
    (In this case, a 10-item list will give approx 100 comparisons, 100 items will give 10.000 comparisons... Yes, bubblesort is rather inefficient)
    Don't visit my new website...
    Unfortunately I cannot use big O notation, for example the number of comparisons for bubble sort is = n(n-1)/2. I must generate similar equations for quick sort and heap sort and also bucket sort
