Inc W...
Yeah, I know it isn't supposed to be a command, but when I type it in and just for fun assemble it,
code is generated that is: Inc·· IND...
Maybe "Inc W"this should generate an error, instead of generating "INC IND"???
Or am I missing some important feature of the assembler?
-Dan
"A saint-like quantity of patience is a help, if this is unavailable, a salty vocabulary works nearly as well." - A. S. Weaver
-Dan
Here comes the trick:
Make sure, bit 7 in the OPTION register is clear so that W is mapped into memory address $01. Then use
inc wreg
instead of inc w, and - voila - you can increment w (and perform similar operations with w as well).
Greetings from Germany,
G
