Upload to BS2 fails & reboot board
Hey all,
I have v2.3.9 software running on an old Win95 Toshiba Libretto 70CT laptop, connected to a Homework BS2.· Debug window opens and talks to BS2 beautifully.· However, when I attempt an identify it will fail to ID anything on the port and at the same time, I see the BS2 board reset itself.· Upload never works (also resets as above).
Any ideas what's going on here?· Did a firmware upgrade on laptop, just to be safe; config'd COM ports many times, removing/disabling LPT, IR, modem, PC cards, etc.· Still no go.· Are there specific port settings that have to be defined in Windows?
The Libretto 70CT is the perfect unit to take along on demos of the BS2, since it's so compact.· It'd be great to get it working.
Any other ideas would be appreciated.·
Andy
Andy
The most important piece of information is the fact that it’s generating an error. What is the message? Is an error generated when you identify or just when you program?
This is on a Libretto 70CT, Win95, serial cable on COM1, software rev 2.3.9. Debug window shows all communications (so maybe the problem is when I transmit to the stamp? Then again, during debug, if I press a key, I see an xmit/recv to the stamp without a reset).
Note that same stamp, board, and cable works fine on another PC. What can could the board to reset like that all of the time?
Thanks.
