If you want larger fonts you might try the "graphics.spin" in the library with the new propeller tool. Run graphicsdemo.spin, he did some amazing things. I gave up on using it as it using alot of memory but that's the only way I know of to get what you want.
······· "What do you mean, it doesn't have any tubes?" ······· "No such thing as a dumb question" unless it's on the internet ········
It should be possible by manipulating the video parameters in TV_Text to paint the pixels less often and draw scan lines more than once, but it's not a simple task.
Use my MPE_TEXT_013 substitution, I posted it for just this purpose. I think there is a preconfigured PAL and NTSC version, but take the NTSC version by all means, as PAL makes no sense on 320x240 displays.
Paul Baker
Paul Baker
