Capacitance Problem?
I have a small board design of my own that works with the SX-Key and SX-Blitz.·
In standalone mode it works ok if I attach a wire (about 12" @ 22ga) to OSC2 and then to nothing else.
If I take the wire off and reset, it does not even get through the initialization routine leading me to think that·the wire serves as a sort of very weak capacitor.· Am I on the right track?
Additional info:
SX18 running at 4mhz, replaced the resonator because I thought that might be defective.· Schematic is attached if it is needed.· One modification that was made since that schematic is that I connected +5 on the LM7805 to the boards +5 (grin, yea, I know, that was a stupid oversight).
John J. Couture
San Diego Miramar College
Additional info:
John J. Couture
No I haven't tried other frequencies because:
1) resonator is soldered in
2) I have a LOT of 4mhz resonators (grin)
John J. Couture
Sorry, I was referring to the different OSC settings in the program code like:
OSCXT1
OSCXT2
OSCHS1
OSCHS2
etc.
You may have better results with another setting.
Robert
I don't know why it worked but at least I know where to start looking.
For others following this thread, these settings are on page 49 of the SX-Key Development System Manual
http://www.parallax.com/dl/docs/prod/sx/SXKeyMan2_0.pdf
OSCXT1 - Normal Crystal/Res, 32khz to 10mhz
OSCXT2 - Normal Crystal/Res, 1mhz to 24mhz
OSCHS1 - High Speed Crystal/Res, 1mhz to 50mhz
OSCHS2 - High Speed Crystal/Res, 1mhz to 50mhz
John J. Couture
