BS1 and 433MHz
quick question, i have the BS1 USB stick unit for development and testing and also 2x 433MHz Tx and 2x 433MHz Rx, now is it going to be possible to run a Rx and Tx on the same device, so say for example,
SERIN 1, N2400, B2
SEROUT 2, N2400, ("SNC", B2)
i have connected the two units to the bs1 on port one and 2 and when that happens it doesn't seem to run, with one tx and one rx on seperate units it works fine. could it be a power issue needing an external regulator for the two to run at the same time or something else?
SERIN 1, N2400, B2
- Stephen
