AA Rechargeable Nimh Batteries — Parallax Forums
jbodjbod Posts: 46
edited 2008-02-22 23:09 in Robotics
Is it ok to run these in the Boe-Bot?
    edited 2008-02-19 00:21
    Yes but you should use 5 of them.
    - Stephen
  • UghaUgha Posts: 543
    edited 2008-02-19 01:02
    Parallax sells a nice item for this called the Boe-Boost Module. It basicly clips into the existing BoeBot battery
    pack and lets you put in a 5th AA-sized battery.
    The item number is 30078
    You can find it by doing a search on the Parallax site for the above number.
    In addition... If you've got a single battery holder already, you can just put them in series with the main holder... that would
    most likely require soldering though.
  • jbodjbod Posts: 46
    edited 2008-02-19 01:06
    Can you run 6? Or is the 7.2v to much for the servos on the Boe-Bot?
    edited 2008-02-19 01:12
    If you have the servo jumper on the BOE set to VDD mode instead of VIN... the servos should be fine.
    edited 2008-02-19 02:29
    The issue is, NiMh are 1.2 volts per battery. Alkalines are 1.5 volts.
    Thus, 4 alkalines give you 6 volts -- 7.5 if you use 5 of them.
    4 NiMh give you 4.8 volts -- which is too close to the brown-out voltage value. 5 gives you 6 volts.
    7.5 volts isn't going to help you much, it'll just increase the amount of heat disappated in the voltage regulator.
    edited 2008-02-22 07:43
    The disappointing thing about NiMh and NiCad batteries is that the battery manufacturers seem to want make them last less than 50% as long as the Alkaline. No matter what you do, you will have to change batteries more often.
    I find it very interesting that you can NEVER find an Alkaline battery with an mAmp/Hour rating attached.
    PLEASE CONSIDER the following:
    Do you want a quickly operational black box solution or the knowledge included therein?······
    ···················· Tropically,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
  • dandreaedandreae Posts: 1,375
    edited 2008-02-22 15:04
    Here is an informative link regarding batteries and mah:· www.starbatteries.com/batteryfaqs.html.· Alkaline batteries typically have a rating of 2500 mah rating.· We have found that the Kirkland batteries last just as long as the Duracell batteries if not longer and are cheaper.·
    Dave
    Dave Andreae
    Parallax Tech Support·
  • WhitWhit Posts: 4,194
    jbod,
    Bean (Hitt Consulting) has some 5 AA holders for sale (which are very hard to find). They are also a good solution.
    See here http://www.hittconsulting.com/miscforsale.html·- they fit perfectly under the BoeBot.
    The Boe-Boost is nice too. I have both so I could check it out for myself.·smilewinkgrin.gif
    Five regular Alkaline batteries are supposed to discharge more fully than four. Five also lets you use the rechargeables too!
    Have fun!
    Whit+
    Post Edited (Whit) : 2/22/2008 11:22:54 PM GMT
