Powering everything with one battery?
If I had a 1,500 mAH 7.2 volt nimh battery plugged into the Board of Education, could I save weight by powering everything from a single power source?
I have a servo controller running two servos, an HB-25 running two 6V motors, and a Parallax GPS receiver. For the PSC and HB-25, I could just wire the power and ground terminals to the power/ground sockets of the BOE's breadboard, right?
2. You should probably run a separate 22 guage (zip cord) power and ground wire for the HB-25 directly to the battery pack.
3. You'll probably have to add a few capacitors -- one across each 6 volt motor + and - leads, one at the HB-25 power input, and probably one at the BOE. The 6-volt motor ones should be non-polarized, probably about 100 uF.
I wouldn't run the HB-25 power and ground wires off the BOE -- the HB-25 can pull some hefty currents, which would damage the BOE board.
[noparse][[/noparse]quote]The PSC should be fine though, right?
Be sure to run heavy enough wires from the PSC to the battery pack and it wouldn't hurt to add extra filter capacitors close to the PSC just like for the HB-25.
Would it be ok to run it from the BOE breadboard sockets if I add capacitors, and how large should the capacitors be?
Breadboard sockets are not high current connections.
What risk do I run if I power them from the breadboard (i.e., will it just not work until the current goes down, or will components be permanently damaged)? How can I minimize this risk (with capacitors, etc)?
Most servo's max out at about 1 amp, when 'stalled', so this shouldn't be an issue. And 1 amp shouldn't melt any traces.
Do you suggest I add capacitors or resistors of any kind to further minimize the risk?
