basic stamp output to energize a relay?
Im using a BS2p and need to output to a relay (5v). Does anyone have suggestions on which one to use and do I need to worry about the emf created when I turn off the relay? Do I need to connect a diode to protect the stamp?
2. Absolutely you'll need a reverse-biased diode across the coil to protect whatever 'driver' you use from the current surge generated when the magnetic field in the coil collapses when you turn it off.
I was searching www.Digikey.com, and they have a SIP reed relay of HE206-ND that might work for you. If the load is inductive, you may have trouble with EMF or inductive type kick, so a diode would be needed. They have a listing for one with a diode built in of HE207-ND but they don't have them in stock. You can also use an Solid State Relay, and the load will be isolated from the inputs. One part is the same package style is part number CLA274-ND. They have these in other pin out and styles, but this might get you started.
David
There are 10 types of people in this world,...
Those that understand binary numbers, and those that don't!!!
