ASM..ENDASM, what am I not understanding?
Hi, Gents.
Are there some assembly codes not permissible within ASM...ENDASM but permissible when using the \ at the beginning of the program line in .SXB?
I was adding some assembly codes into an .SXB program, and I experienced something which has me confused. The following illustrates the point.
This compiles successfully in .SXB
This does not compile successfully in .SXB
If I put the previous one in an external .SRC file and use the INCLUDE file, it compiles just fine.
Thank you for your help in furthering my understanding of SX programming.
\_test macro 1 \ bank \1 \endm
ASM _test macro 1 bank \1 endm ENDASM
(for .SXB file) INCLUDE "src.src" (SRC.SRC file) _test macro 1 bank \1 endm
Any ASM line that contains a "\" must be prefixed with the "\". Yes EVEN if it is inside an ASM...ENDASM block.
Bean.
www.iElectronicDesigns.com
I don't know what I did wrong earlier, but yesterday (Feb 20) I was able to get the program running correctly with the ASM...ENDASM statement without the need for a \ at the beginning of each line.
Post Edited (Sens-a-Dat) : 2/21/2008 12:35:09 PM GMT
