Possible Reasons for Poor Print Quality/Missed Droplets w/Inkjet Serial Board?
Zoot
See attached. I'm getting missed/bad droplets pretty consistently. I only have a few possible explanations so any other possibles are welcome, plus of course, solutions:
- bad bitmaps loaded onto inkjet board EE ($00-$7F are the preloaded font, $80-$FF are a font I downloaded), but problem is same when using either
- clogged print head / bad print head? If so, how to clean?
- poor contact between print head and cartridge holder? (but I checked this, wiped contacts, reseated)
- poor contact(s) with ribbon cable? (checked it, ditto)
- bad pin (or bad contact) on driver pin on board? (seems really really unlikely, but it's possible, I guess)
Cleaning of nozzles by wiping gently with lint-free cloth is either recommended or specifically discouraged depending on cartridge, type of ink, etc. So I cleaned nozzles very very gently with lint-free cloth (nothing to lose, really).
Works much better -- much better contrast, no missing rows.
In concept, it merely runs a lot of ink through each nozzle until the problem clears up.
Another contributing factor maybe that you are either too far or too close to the surface for proper resolution.
And yet another, is non-linear motion and jitter during the actual printing will somewhat degrade the results.
It looks like you may have all three.
Regarding misfires, each dot has a tiny heater that fires the ink. If you burn out a heater, it is gone for good and you must use another cartridge. At least it is replacible. The documentation is very careful to explain how to avoid this and if you are using the 'stock programs', I don't think you show be worrying about it.
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
If the nozzles on the print cartridge appear clean, but they are still not squirting properly - fill a small cup with 1/4 inch of rubbing alcohol. Place cartridge in cup so the nozzles can soak. Should be fine after 15 minutes. First few prints might have poor quality, but it should darken back up quickly.
Be glad you have an HP. Much easier to clean than Epson.
I also wonder if the alcohol-saturated lens-cleaning tissues like the Bausch & Loumb "Sight Savers" that Costco sells would work.
Bagel crumbs WILL cause problems
