No BASIC Stamp Found.
I just installed all of the boebot stuff on my computer.· I have used the same robot previously, and it worked correctly.· Now, on my computer, it will not download a program to the robot.· The download progress says that there is a loopback and echo for it, but no basic stamp found. Please help me.
Post Edited By Moderator (Chris Savage (Parallax)) : 2/20/2008 6:08:33 PM GMT
- Stephen
So, you may have "Checked all that stuff", but it STILL sounds like there's a problem there. How did you check it? With a volt-meter? Did you REMOVE and RE-INSERT the BS2 chip?
Did you perhaps check a 9-volt battery with a volt meter while it's not connected to anything? You need to check it under load -- while it's connected and powering stuff.
