Power supplies (Paranoid newbie strikes again)
If you've read my past posts, then you know I'm a bit paranoid when it comes
to possibly damaging my BS2.
So here's another issue with me being paranoid...
I found a wall wart that fits into the BOE... but before I apply power to it I wanted
to verify that its completely compatible with both the BOE and the BS2.
Its stats look pretty identical to the one sold on the Parallax site (Item code 750-00008)
but I still would like one of you gurus to give me the OK on it.
It's from a rechargable flash light... its specs are:
120VAC/15W input
9VDC/300mA output
Its center positive and says its a "Class 2 power supply" whatever that means.
Please don't be annoyed by my smoke-a-stamp phobia [noparse];)[/noparse]
120VAC/15W input
9VDC/300mA output
Back to general rules about wall warts
The specs say how much current the supply can provide and what voltage will be present at that current (9V at 300mA). It says nothing about the voltage when the current drawn is lower. Unless the wall wart is well regulated (not the usual case), the voltage will be higher under light loads. Measure it under different loads if you're curious. The input rating tells you what the wall wart is designed for in terms of input (120VAC or, for some, 100-240VAC) along with the amount of power drawn maximally (15W).
Class 2 refers to operating conditions for testing. For example, a Class 2 power supply is not designed to work safely in an explosive atmosphere.
Again, when in doubt about a power supply, measure its output voltage under no load or low load conditions, then under full rated load. Parallax indicates on its boards and documentation what voltages its equipment is designed to operate with. Many of its boards are specified for a 6-9VDC power supply. If you try to operate it at lower voltages, the board may not be able to supply regulated 5V and the microprocessor may reset unexpectedly. If you try to operate it at higher voltages, the regulator may overheat or input filter capacitors may exceed their rating and explode (if the voltage is high enough and the current available is high enough). Often the regulators themselves will withstand 30+V without damage, but will overheat and shutdown if you try to operate the microprocessor at the higher voltages. Some of the regulators that Parallax uses will withstand reverse polarity power without damage, but other parts (like servos) that are directly connected to the power input will be damaged or destroyed.
Let me make sure I fully understand... the rating on the wall wart is the min value it'll put out at the stated amps? That makes it rather dangerous trying to match wall warts with projects, doesn't it?
I can't figure out how to test under full load because I don't have a barrel jack spare... is it needed to rule out a supply if the no-load is too high to start with?
I've gone around my house testing wall-warts left and right only to discover that their ratings are nothing like the values I get at no-load... a 6v ended up testing at 18volts!
Either I'm doing something wrong or I don't understand some basic fact... either way I'd greatly appreciate some guidance.
The only light of hope I've found so far are two supplies... one rated at 5v/1.5a that reads 5.17v at no-load and another 15 year-old one rated 9v/200ma and tests 8.77.
I don't want to try them til I'm 100% sure I understand everything.
I know questions like this are annoying but I won't know unless I ask, right?
If you use power sources within the recommended range, the regulator will not overheat and it can withstand the peak voltages seen at very low loads.
The two supplies you mentioned, the 5V one and the 9V one may be regulated (have a regulator built-in). You want to make sure that's so rather than just assuming that you can use the 5V supply for logic circuitry without a regulator. The best way to do that is to find a manufacturer's name and part number and download the datasheet for the supply to check.
