micro serial dual motor controller problem
I just got the micro serial dual motor controller and i seem to be having some issues.
it will be used to control 2 motors independently using a BS2 for brains
the instructions say the default configuration is 2 motors numbered 2 and 3
the code (in PBASIC):
SEROUT 15, 84, [noparse][[/noparse]$80, 0, 0, 127]
will run both motor in reverse and i have full control over speed
SEROUT 15, 84, [noparse][[/noparse]$80, 0, 1, 127]
will run both motors forward and i have full control over speed
and nothing happens with any other motor number
i attempted to change the configuration using:
SEROUT 15, 84, [noparse][[/noparse]$80, 2, 2]
as it states in the manual
one motor turns at full speed until it is reset and then no apparent change to the configuration is seen
any help would be much appreciated
