Absolute beginner
what is the minimum of electronic components that I need to get the SX running and be able to comunicate with SX-Key. If I understood it right, the SX itself has no EEPROM integrated, where do I store my program / data?
As there is no a BASIC compiler for the SX (and I heard that with that IRQs are possible what I really happy to hear) is there any reason I should stay with the BASIC Stamp modules??
Best
Thomas
Best
Thomas
AT minimum you need a SX chip (you can use internal clock generator if you don't need a very good accuracy). You can buy the tool kit at following link: SX Tech Tool Kit LITE
Then the program you write by assembly or SX-B (basic) is stored in to the internal flash memory. For your data there is of corse a RAM.
If you need to store some datas also without power supply, You have to use a EEPROM or similar devices.
Loojade
If you want to use an internal oscillator;
You need a GND going to VSS.· You need 3.3V-5V going to VDD.· You will want to tie the RST pin to·VDD (with a 10k resistor).
You will want a 4 pin header that connects to OSC1, OSC2, VDD,VSS.
If you look in the manual, there is a 'programming interface' picture that shows this.· It is al you need.
You can program and operate the SXes with just a 5 volt regulator, a reset circuit, and the internal 4mHz oscillator. I believe the SX-Key manual shows a minimum circuit on page 13 or so.
Their is SX/B that is Basic for the SX and SX/Asm that is Assembler for the SX. Both are included in one software package called the SX-Key IDE.
The SX-28 has 2k of 12bit program memory and the SX-48 has 4k of 12bit program memory. Sometimes this is referred to as internal EEPROM. In addition there are 8-bit SRAM registers for storing variables and other temporary items. The SX-48 has 262 available and the SX-28 has roughly half that.
The really nice thing abou the SXes is that they are cheaper than the BasicStamp at this point. You can buy a demoboard for about $20USD.· And of course, the DIPs are roughly $3-4 each.
And finally, SX/C for C programers is available in Beta form.· If you took a look a PICs, all this software and support would cost you big big bucks.l
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
Post Edited (Kramer) : 2/20/2008 4:41:45 PM GMT
