Will this circuit work - power latch
Hi everyone,
Does anyone know of an IC that I can use that will perform the same task as a computer power circuit.
I basically want to be able to turn my device on with a momentary switch and turn it off the same way. (Like a computer does).
I am wanting to turn a hybrid into a mini arcade PC.
Thank you
Check out my robot using the propeller RECONAUTOR
If you like my avatar then check this out Propeller Domed Stickers for sale
Post Edited (computer guy) : 3/15/2008 6:07:09 AM GMT
Thank you
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Thank you for your suggestion however I am after something that is an off the shelf solder it in and go type of IC.
Thank you
The coin slot pulse might have to go to a latching relay in order to remain ON for a full game cycle. The PC could shut off the latching relay at the end.
So, that wouldn't be an IC; that would only turn on, the PC would turn off. And, there would not be any audio/video output loop trying to get people to play when the machine doesn't have a paying customer.
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
You know how modern PC's that when you push the power button they turn the PC on.
This is what they do.
1. Power supply provides 3.3v to motherboard.
2. Motherboard detects that power button is pressed and joins 3.3v to PS_ON.
3. Power supply detects high on PS_ON and gives full power to computer.
I would like to replicate this with a home project.
Thank you
You can use 3.3v for everything if that is what the PS_ON also requires.
Another choice is the good old 555 timer in a CMOS version like the 7555.
I will look into these further in the morning.
Usually I start out with 74HC??? unless something is suggested.
The 6v will come directly from the power supply and the output will go to the 5v and 3.3v regulators.
Thank you
rise time for the clock faster. As it stands, you have a very slowly rising
signal into the clock pin. Logic devices don't usually like such slow
rise times.
What does pin 13 of the 4013D drive?
Post Edited (phil kenny) : 3/17/2008 5:39:41 AM GMT
Thank you
