Serial to Parallel output
I ran a couple searches on the obex for an object that "expands" the outputs of the prop. My thinking is that you can take a serial to Parallel IC and use a couple pins(clock/data) to simulate extra outputs. With an 8bit serial to parallel IC, you can gain an extra 6 ouputs for every 2 pins used on the prop. I'm sure there are a bajillion other applications for this, but I want to use one of these IC's to control a 4-phase stepper motor(needing 8 ouputs) with only the two prop pins.· Basically, the prop sends the s-p IC a data stream to toggle the IC's ouputs high/low, and these outputs are fed into a quad H-bridge that drives the stepper.
I'm sure this has been done, but I haven't turned up much.
