PWM for motor speed control
A friend of mine is asking for help with a project. He's got a windshield wiper motor from a car, and has it mounted to a bracket and somehow it moves a fishing pole. The purpose is to move the lure in such a way that's more inviting to the fish. He's taking care of the mechanical aspects, but asked for help with the electronics.
He wants to have an adjustable speed for the motor. I had first thought to pulse the motor, going 1 revolution, stop, pause for some time, repeat. There is a switch on the motor that pulses once per revolution to facilitate this. But the motor coasts for about 1/2 a revolution when the power is removed. I don't think this is the answer. And my friend requested that the motor rotates at a constant rate, but that the rate be adjustable.
My second thought, use PWM to vary the speed of the motor. I want to use parts that I already have on hand. I have a IRL2910 MOSFET that I think might be up to the challenge. I also have a few TIP120G Transistors on hand. I want to provide the Pulses with a Propeller as well as providing input via a switch to change speeds, and output via a 7 segment LED to indicate current speed. A propeller is overkill, as the simplest microcontroller could handle this task, but well....
Some specifics for the motor. I checked current drawn by the motor...
I would like some suggestions on what to use, the MOSFET or the Transistor? or other?
Thanks - Brian
- with no load - about 1.2 amp
- start up current is approx 3 amp
- current when stalling the motor jumps to around 5 amps
- using a 12 volt deep cycle battery to power this project.
Thanks - Brian
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
