Need some help with this 20x4 LCD
I just ordered this LCD from Digi-key: Optrex 20x4. Data Sheet
I have questions about the back light. I *THINK* that this is covered on page 6 of the data sheet, but I'm not sure. Anyway, what voltage do I drive the back light with? There are two back light connectors, two pins on the main 16-pin connector and then a separate 2-pin connector. I'm assuming that they both need to be connected to power, but it's not mentioned in the data sheet.
Also, what the heck is note 4 on page 7 referring to?![confused.gif](http://forums.parallax.com/images/smilies/confused.gif)
Post Edited (MarkS) : 2/15/2008 6:09:15 PM GMT
I suspect that the reason why two sets of back light connectors appear may be just for convenience, as they seem to be the same to me. I can't see how it would hurt to connect them both, but I also don't see the necessity of doing so.
The circuit shown on Page 9 will show you what is required for the contrast circuit. I'm not sure what Note 4 on Page 7 is either, but I wouldn't worry about it too much unless the LCD doesn't perform as expected.
Bruce Bates
"Genius is one percent inspiration and ninety-nine percent perspiration."
Thomas Alva Edison
2. According to the spec sheets, the two sets of connectors for the backlight are the same, as Bruce said.
3. Ignore note 4. I think it has to do with the voltages applied to the LCD connections internal to the board.
Post Edited (MarkS) : 2/21/2008 3:36:58 AM GMT
I just looked at the spec sheet again, and the drawing that you can get to from Digikey's page. It looks like there are two LED's in parallel, EACH of which can be supplied with 30ma. In that case, you want 60ma (maximum) from your supply, which translates to a 25-33 ohm (minimum) resistor with a 5V supply or a 5 ohm (minimum) resistor with a 3.3V supply (assuming that the backlight voltage is less than 3.3V).
Try 5V with a 33 ohm resistor. That should work if you've got a 3.5V drop across the backlight.
Where did you find this information in the data sheet? All I can find are two sets of LED connectors on the PCB, but I cannot find a reference as to whether both are needed.
In the various references, the pins are labeled A and K, for LED anode and cathode. All implications are that the two A's and the two K's are the same.
