serial to parallel IC — Parallax Forums
shmowshmow Posts: 109
edited 2008-02-15 04:16 in Propeller 1
I've a BS2 that uses a 74HC595 IC for serial to parallel discrete signals.
Here's the watered down version of what I had written for the stamp:
 ' {$STAMP BS2}
 ' {$PBASIC 2.5}
 'serial output for serial/parallex IC: - when button (pin 3 - momentary) is pressed
 '                                        propeller sends out serially binary value of 1111
 '                                      - when BUTTON (PIN 3 - momentary) is released
 '                                        propeller sends out serially binary value of 0000
Btn                  PIN     3         'push button - momentary
btnWrk               VAR     Byte
Binary_Pattern       VAR     Byte      'variable for binary value
Pin0_Clock           CON     0
Pin1_DataOut         CON     1
Pin2_Latch           CON     2
Main:
  BUTTON Btn, 0, 255, 0, btnWrk, 1, Did_Press
  Did_Press:
  IF btn = 0 THEN                      'when button pressed value of 1111 is sent out on pin 1
    Binary_Pattern = %00001111         'binary value
    GOSUB Out_74HC595                  'sub routine call
  ENDIF
  IF btn = 1 THEN                      'when button released value of 0000 is sent out on pin 1
    Binary_Pattern = %00000000         'binary value
  ENDIF
GOTO Main
Out_74HC595:                           'sub routine
    SHIFTOUT Pin1_DataOut, Pin0_Clock, MSBFIRST, [noparse][[/noparse]Binary_Pattern]
    PULSOUT Pin2_Latch, 5
    RETURN
I've edited as far as I can for the prop but I'm not sure how to use the Pin0_clock & MSBFIRST features of
the stamp for the prop.
How do I handle these parts?
Here's the Spin that I've done so far:
'' -- input P23 turns on LED on pin P4
'' -- if LED is on then P 0, 1 & 2 send signal to 74HC595 (serial-parallel IC)
{{LED                       Pushbutton                74HC595
                                3.3V
        100 Ω    LED                                 PROP      74HC595
     P 4 ───────┐            │                    P 1 ─── P 14 Data In
                               ┤Pushbutton          P 0 ─── P 11 Clock ???
                   GND           │                    P 2 ─┳─ P 12 Latch
                          P 23 ─┫                           10 kΩ
                                  10 kΩ                   GND
                                GND
CON
    _clkmode = xtal1 + pll16x
    _xinfreq = 5_000_000
OBJ
    BS2 : "BS2_Functions"    ' Create BS2 Object
PUB Btn_LED
  dira[noparse][[/noparse]4] := 1                            ' make the pin an output
  repeat
    outa[noparse][[/noparse]4] := ina[noparse][[/noparse]23]                    ' output state equals input state
    if outa[noparse][[/noparse]4]
     BS2.start (31,30)
     BS2.SEROUT_dec(1,00001111,9600,1,8)
     BS2.PULSOUT(2,5)
    else
     BS2.SEROUT_dec(1,00000000,9600,1,8)
     BS2.PULSOUT(2,5)
