I’m not clear on what you mean…If you’re referring to the BS2 OEM Module we sell, all it requires to program is the serial connection to the PC and power. Either a regulated 5V to its VDD pin or 5.5-15V to its VIN pin. You wouldn't use the serial connection on the BOE, you would use the one on the OEM Module.· I hope this helps. Take care.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support
