PING))) help
Hello,
I am using the PING))) sensor with the Basic Stamp 2 in order to measure the distance of the object. I have following logic to covert the pulses into the distance:
Get_Sonar:
Ping = IsLow ' Make Trigger 0-1-0
PULSOUT Ping, Trigger ' Trigger PING)))
PULSIN Ping, IsHigh, rawDist ' Measure Echo Pulse
rawDist = rawDist */ Scale ' Convert To uS
rawDist = rawDist / 2 ' Remove Return Trip
inches = rawDist ** RawToIn ' Convert To Inches
cm = rawDist ** RawToCm ' Convert To Centimeters
RETURN
The only problem I am having is that the sensor detects maximum of 61 Inches, no more that that. That is about half of the maximum detection range.
Could someone direct me to how I can go about to fix this problem?
Sorry, I am new at this.
Thank you,
Get_Sonar:
RETURN
Thank you,
Dave
Dave Andreae
Parallax Tech Support·
