Multiple Ultrasonic Sensor
Hi there!
I'm working on a wall following robot. I used three ultrasonic sensor - 2 on the left side of the robot and the other in front of the robot. The problem is, when I use 3 ultrasonic sensor, the IC becomes hot. So I'm wondering whether it is really possible to use 3 ultrasonic sensor at the same time? Please someone help me. Thank you.
When you say "the IC becomes hot", that covers a lot of territory. Which specific IC is getting hot, and on which PCB.
How do you have the PING's powered?
It's probably a bit late to tell you this now, but Parallax offers a PING rotator, so that you can use one PING to sense in more than one direction. It's a good deal less expensive than having multiple PING's. Here is where it may be found: http://tinyurl.com/26kpgm
By using the PING rotator, you can scan a full 180 degrees from one side to the other. You would also have BOTH sides of your robot fully covered, rather than having 2 on the left, and one one in the front, as you have it now.
Bruce Bates
"Genius is one percent inspiration and ninety-nine percent perspiration."
Thomas Alva Edison
