Moving from Development board to vero-board... question on Vdd...
I've got a prototype running on the BOE and I want to move over to vero-board to make things a bit more permanent. As far as I can tell, if I have anything that's powered by Vdd that is not supplied by a HIGH pin, I need to include a separate 5V Voltage Regulator. Could someone please verify that for me? Also, I see 2 capacitors on the development board in series with the power supply (+ and - terminals). I'm not sure if those are only on the battery or also on the DC wall plug, but is that something I should also incorporate into the vero-board? Is there anything else I'll be missing for proper and safe execution? I'm not worried about re-programming once on the board. This is my first real project and the first time going to vero-board (first time soldering a real circuit, first time lots of different things!)
I'm excited but also a bit nervous and want to make sure I solder my first board right. Any help will be greatly appreciated. I'll post the project on the boards once I've gotten everything complete.
Post Edited (Jed) : 2/14/2008 3:11:24 PM GMT
I'm excited but also a bit nervous and want to make sure I solder my first board right. Any help will be greatly appreciated. I'll post the project on the boards once I've gotten everything complete.Post Edited (Jed) : 2/14/2008 3:11:24 PM GMT
I alway put a separate 5V Voltage Regulator on all of my Projects unless the load is less then 200 milamp for the hole project these Voltage Regulators do not that much and do not want over load· Voltage Regulator just because i want to save 1 to 3 Dollars
Yes· I see 2 capacitors on the development board
One is on the INPUT· PIN of Regulator and one is on the OUTPUT PIN
The one on the Out Pin is the one you must use
Now if you are powering your project from a wall wart you may want to put one on the in put as well because not all wall wart have enough of a capacitor to filter AC ripple out
When i built my power supplys for my projects i use at least a 47000 uf capacitor then i might·not use one at the input of the Regulator
I hope this help you in what you want to do
··Thanks for any·
Sam
If you're circuit is drawing more than 200 mA, typically you'll need to mount a heatsink on the voltage regulator to keep it running smoothly.
parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/txtSearch/regulator/List/1/ProductID/242/Default.aspx?SortField=ProductName%2cProductName
Can I just duplicate what the BOE uses and use 1000uf caps? Is there any harm in going higher, like maybe 3300 uf? so I can order everything from parallax?
Post Edited (Jed) : 2/19/2008 6:24:50 PM GMT
Also, from looking at the BOE schematic. It looks like only one of the 1000uf caps is connected to the regulator. The other one is apparently connected to the reset button.
Post Edited (Jed) : 2/19/2008 11:35:26 PM GMT
- Rick
