Human detection
I want to design a bot that locks onto an object with IR (or perhaps ping)
then senses if its human or not.
Is there any way to do this? I had high hopes for the PIR sensor but it seems
it only detects movement.
Anyone know if the movement is only in the human temp range or is it any
movement?
Oh... also... will an IR LED throw off the PIR sensor?
movement?
Reflective IR is between 0.7 and 3 micrometers.
Thermal IR is betwene 3 and 14 micrometers.
Humans emit between 8.6 and 9.6 micrometers.
Also... would an object in front of the PIR detector affect it's "sight"? For example, a thin
piece of felt or paper a half inch or so in front of the detector.
My idea is possibly using IR leds to "lock on" to a stationary target then sweep the PIR left
and right to simulate movement enough to trigger it if its human-range.
Does anyone know of a better way to detect humans?
- Stephen
other way senses that a person is not a lifeless object.
I considered using some kind of skin tone identifying process, but the RGB color sorter on the parallax site only works at about
a 1" distance. And it's a little expensive.
I'd need something that'd work from about a foot away.
As far as I can tell... PIR is my only hope.
Stevenmess2004: I have one I tried to rip apart, its even less sensitive than the parallax PIR.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
The term "skin tones" has been used more than once in this thread. That is not one singular color. Like M&M's we humans come in many different colors, thus using "skin tones" would be a bit difficult, if not impossible.
The I/R heat emission signature is fine, but I'm not sure we all would "look" the same there either. So too, clothing will alter the I/R heat emission signature to one degree or another.
Franklin (Stephen) said it all above, when he stated:
"That would depend on how you define "Human" to your program."
There is a good deal more to that statement than may meet the eye!
Bruce Bates
"Genius is one percent inspiration and ninety-nine percent perspiration."
Thomas Alva Edison
http://www.robot-electronics.co.uk/acatalog/Thermal_Array_Sensor.html
Carl
The page with video: share.crustcrawler.com/NorrisLabs/FollowMeHexCrawler/FollowMe.htm
Project description: http://forums.parallax.com/showthread.php?p=615077
·· To answere your question. A Thermal IR filter is available but very expensive. There is a PIR sensor that has a built in filter that targets the human IR range and filter out other thermal IR. (Eltec 442-3)
http://www.acroname.com/robotics/parts/R1-442-3.html
Placing a loosely woven cloth in front of the PIR is possible with some IR attenuation. Experimentation will be needed with the type of cloth. There is a product called Poly IR-4 and Poly IR-9. Its a plastic material that passes thermal IR and looks black to the naked eye.
http://www.fresneltech.com/pdf/POLYIR.pdf
Post Edited (LilDi) : 2/14/2008 4:48:00 PM GMT
They Demo is free and you can use pictures to test filters. you might want to try it and see how it works for you and your environment.
Added Photo examples.
The one of my daughter is using:
Gaussian blur
Skin filter
RGBfilter Red
and center of Gravity.
I zoomed in on the output image so you could see the box and read the text, the X and Y are variables that can be used to control servos, make calculations what ever you can think up.
the photo of lots of people is just the stock skin filter,
DGSwaner
Post Edited (Dgswaner) : 2/19/2008 4:02:44 PM GMT
