Resistor wire loose in black sockets on HomeWork Board
The leads on the resistors in the What's a Microcontroller kit are so thin that they don't make a good connection in the black sockets in the prototyping area. The wire is just sitting in the socket, there is no tight fit. The resistors fit the white breadboard sockets fine, I can feel a little resistance when I insert them there. Other leads like the jumper wires fit fine in all the sockets.
Right now I have to wiggle the resistors to make contact. Not a very reliable setup. I will go buy new resistors with thicker leads as a workaround.
Is there a trick?
Other than that, this kit is great! This is my first time with a BASIC Stamp and I have set up all the LEDs to flash in circle at varying speeds and it took less that an hour.
Is there a trick?
- Rick
Dave
Dave Andreae
Parallax Tech Support·
