The DATA command
Hi!
i want my stamp to read several data and check if it is within the limits...it not then print a string...
here is my program.
' {$STAMP BS2p}
' {$PBASIC 2.5}
varv VAR Word
speed VAR Byte
cool VAR Byte
air VAR Byte
airflow VAR Byte
pressure VAR Byte
load VAR Byte
voltage VAR Byte
sp VAR Byte
rpm VAR Word
kylare VAR Byte
luft VAR Byte
flode VAR Byte
tryck VAR Byte
laddning VAR Byte
volt VAR Byte
spbp VAR Nib
char VAR Byte
· a VAR Byte
Tx············· CON···· 8······················ ' connects to Emic SIn
Rx············· CON···· 9······················ ' connects to Emic SOut
Busy··········· CON···· 10······················ ' 1 = busy
Rst············ CON···· 11······················ ' low to reset Emic TTS
AOut··········· CON···· 12····················· ' audio out from Stamp
Baud··········· CON···· 1021
OK············· CON···· $55
EOM············ CON···· $AA
Say············ CON···· $00
' read current value
main:
STORE 2
READ· 11,varv.LOWBYTE
READ 12,varv.HIGHBYTE
READ 13,speed
READ 14,COOL
READ 15,air
READ 16,airflow
READ 17,pressure
READ 18,load
READ 19,voltage
READ 20,spbp
'read limitvalues
STORE 4
READ 17,sp
READ 27,rpm
READ 37,kylare
READ 47,luft
READ 57,flode
READ 67,tryck
READ 77,laddning
READ 87,volt
'check values
IF speed>sp THEN highspeed
IF varv>rpm*100 THEN highrpm
IF cool>kylare THEN highcool
IF air>luft THEN HIGHair
IF airflow<flode THEN lowflow
IF pressure<tryck THEN lowpressure
IF load>laddning THEN highload
IF voltage<volt THEN lowvoltage
highspeed:
DATA "WARNING! HIGH SPEED!"
GOTO printit
highrpm:
DATA········ "WARNING! HIGH RPM!"
GOTO printit
highcool:
DATA··· "WARNING! HIGH COOLING TEMP!"
GOTO printit
highair:
DATA····· "WARNING! HIGH AIRTEMP!"
·GOTO printit
lowflow:
DATA····· "WARNING! LOW AIRFLOW!"
·GOTO printit
lowpressure:
DATA···· "WARNING! LOW AIRPRESSURE!"
·GOTO printit
highload:
DATA······ "WARNING! HIGH LOAD!"
GOTO printit
lowvoltage:
DATA······ "WARNING! LOW VOLTAGE!"
·GOTO printit
printit:
FOR a=1 TO 20
READ a,char
DEBUG char
NEXT
END
all i get is a bunch of yyyy.
why?
regards
Robban
Post Edited (Robban) : 2/12/2008 7:08:39 PM GMT
here is my program.
' {$STAMP BS2p}
' {$PBASIC 2.5}
varv VAR Word
speed VAR Byte
cool VAR Byte
air VAR Byte
airflow VAR Byte
pressure VAR Byte
load VAR Byte
voltage VAR Byte
sp VAR Byte
rpm VAR Word
kylare VAR Byte
luft VAR Byte
flode VAR Byte
tryck VAR Byte
laddning VAR Byte
volt VAR Byte
spbp VAR Nib
char VAR Byte
· a VAR Byte
main:
STORE 2
READ 13,speed
READ 14,COOL
READ 15,air
READ 16,airflow
READ 17,pressure
READ 18,load
READ 19,voltage
READ 20,spbp
'read limitvalues
STORE 4
READ 17,sp
READ 27,rpm
READ 37,kylare
READ 47,luft
READ 57,flode
READ 67,tryck
READ 77,laddning
READ 87,volt
'check values
highspeed:
GOTO printit
highrpm:
GOTO printit
highcool:
GOTO printit
highair:
·GOTO printit
lowflow:
·GOTO printit
lowpressure:
·GOTO printit
highload:
GOTO printit
lowvoltage:
·GOTO printit
printit:
FOR a=1 TO 20
READ a,char
DEBUG char
NEXT
END
why?
regards
Robban
Perhaps you want to use a DEBUG statement as in DEBUG "WARNING! LOW VOLTAGE!" rather than a DATA statement.
If you still want to use the DATA statement, you need a label on it so that you have some way to refer to the address
where the data is stored in the program memory. You would then use the label when you GOTO the printit routine.
but how would it look like if i want to use a string of hex...like the following
$1E,$11,$11,$1E,$11,$11,$1E,$00
i tried B var $1E,$11,$11,$1E,$11,$11,$1E,$00
but all i got what "Expected a varible"
So i wrote a tedious program, now i wonder if it is possible to make this smaller with the same function??
here is the program
' {$STAMP BS2p}
' {$PBASIC 2.5}
CHAR VAR Word
Q VAR Byte
Q=0
Z VAR Byte
SEROUT 2,2409,[noparse][[/noparse]$19]
test:
DATA "HELLO WORLD",0
printit:
DO
Q=Q+8
READ Z, char
GOSUB CHARS
Z=Z+1
LOOP UNTIL (CHAR=0)
END
CHARS:
IF CHAR="A" THEN A
IF CHAR="B" THEN B
IF CHAR="C" THEN C
IF CHAR="D" THEN D
IF CHAR="E" THEN E
IF CHAR="F" THEN F
IF CHAR="G" THEN G
IF CHAR="J" THEN J
IF CHAR="K" THEN K
IF CHAR="L" THEN L
IF CHAR="M" THEN M
IF CHAR="N" THEN N
IF CHAR="P" THEN P
IF CHAR="R" THEN R
IF CHAR="S" THEN S
IF CHAR="T" THEN T
IF CHAR="U" THEN U
IF CHAR="V" THEN V
IF CHAR="W" THEN W
IF CHAR="0" THEN ZERO
IF CHAR="1" THEN ONE
IF CHAR="2" THEN TWO
IF CHAR="3" THEN THREE
IF CHAR="4" THEN FORE
IF CHAR="5" THEN FIVE
IF CHAR="6" THEN SIX
IF CHAR="7" THEN SEVEN
IF CHAR="9" THEN NINE
GOTO CH
RETURN
A:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$11,$11,$1F,$11,$11,$0A,$04,$00]
RETURN
B:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$1E,$11,$11,$1E,$11,$11,$1E,$00]
RETURN
C:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$0E,$11,$10,$10,$10,$11,$0E,$00]
RETURN
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$1E,$11,$11,$11,$11,$11,$1E,$00]
RETURN
E:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$1F,$10,$10,$1C,$10,$10,$1F,$00]
RETURN
F:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$10,$10,$10,$1C,$10,$10,$1F,$00]
RETURN
G:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$0E,$11,$11,$13,$10,$11,$0E,$00 ]
RETURN
J:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$0C,$12,$02,$02,$02,$02,$07,$00]
RETURN
K:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$11,$12,$14,$18,$14,$12,$11,$00]
RETURN
L:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$1E,$10,$10,$10,$10,$10,$10,$00]
RETURN
M: SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$11,$11,$11,$11,$15,$1B,$11,$00]
RETURN
N:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$11,$11,$13,$15,$19,$11,$11,$00]
RETURN
P:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$10,$10,$10,$1E,$11,$11,$1E,$00]
RETURN
R:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$11,$12,$14,$1E,$11,$11,$1E,$00]
RETURN
S:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$0E,$11,$01,$0E,$10,$11,$0E,$00]
RETURN
T:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$04,$04,$04,$04,$04,$04,$1F,$00]
RETURN
U:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$0E,$11,$11,$11,$11,$11,$11,$00]
RETURN
V:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$04,$0A,$11,$11,$11,$11,$11,$00]
RETURN
W:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$11,$1B,$15,$11,$11,$11,$11,$00]
RETURN
ZERO:
SEROUT 2,240,[noparse][[/noparse]$1A,$40,$10,Q,10,$18,$08,$0E,$11,$19,$15,$13,$11,$0E,$00]
RETURN
ONE:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$0E,$04,$04,$04,$04,$0C,$04,$00 ]
RETURN
TWO:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$1F,$08,$04,$02,$01,$11,$0E,$00]
RETURN
THREE:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$0E,$11,$01,$06,$01,$11,$0E,$00]
RETURN
FORE:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$02,$02,$1F,$12,$0A,$06,$02,$00 ]
RETURN
FIVE:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08, $0E,$11,$01,$0E,$10,$10,$1F,$00 ]
RETURN
SIX:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$0E,$11,$11,$1E,$10,$08,$06,$00 ]
RETURN
SEVEN:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08, $08,$08,$08,$04,$02,$01,$1F,$00 ]
RETURN
NINE:
SEROUT 2,240,[noparse][[/noparse] $1A ,$40, $10, Q,10, $18,$08,$0E,$11,$01,$0F,$11,$11,$0E,$00 ]
RETURN
CH:
SEROUT 2,240,[noparse][[/noparse] $10,Q+3,17,CHAR ]
RETURN
I'm not sure what you're trying to accomplish with this program, but as it it is it probably won't do anything useful, and will·may terminate prematurely. All of the statements in the A: - NINE: routines terminate with a RETURN statement and a GOSUB was never issued. The problem begins in the CHARS routine as you can see below in this line extracted from your program:
CHARS:
IF CHAR="A" THEN A
The THEN is an implied GOTO with the target routine as "A:", and is not a GOSUB. You must either change the implied GOTO to a GOSUB or change the A: - NINE: routines appropriately.
As far as the DATA statement is concerned, HEX is fine in a DATA statement, if that's what you were trying to do:
HexData DATA $10,$99,$A1,$B7,$D4,$C2,$A9,$BB,$55,$21 etc
Bruce Bates
"Genius is one percent inspiration and ninety-nine percent perspiration."
Thomas Alva Edison
Post Edited (Bruce Bates) : 2/18/2008 8:58:39 PM GMT
' {$STAMP BS2p}
' {$PBASIC 2.5}
AA VAR Byte
CHAR VAR Word
Z VAR Byte
CH VAR Word
Q VAR Byte
X VAR Byte
DATA "S",0
' MASK OUT ONE FONT
TESTA:
DO
READ Z, ch
GOSUB MAIN
Z=Z+1
LOOP UNTIL (CH=0)
END
MAIN:
SEROUT 2,240,[noparse][[/noparse]$1A ,$40, $10, 10,$1C, $18, $08] ' SET THE VFD TO GRAPHIC MODE
LOOKUP CH,[noparse][[/noparse]A,B,C,D,E,F,G,J,K,L,M,N,P,R,S,T,U,V],AA ' LOOK FOR "S"
' EEPROM DATA
A DATA $11,$11,$1F,$11,$11,$0A,$04,$00
B DATA $1E,$11,$11,$1E,$11,$11,$1E,$00
C DATA $0E,$11,$10,$10,$10,$11,$0E,$00
D DATA $1E,$11,$11,$11,$11,$11,$1E,$00
E DATA $1F,$10,$10,$1C,$10,$10,$1F,$00
F DATA $10,$10,$10,$1C,$10,$10,$1F,$00
G DATA $0E,$11,$11,$13,$10,$11,$0E,$00
J DATA $0C,$12,$02,$02,$02,$02,$07,$00
K DATA $11,$12,$14,$18,$14,$12,$11,$00
L DATA $1E,$10,$10,$10,$10,$10,$10,$00
M DATA $11,$11,$11,$11,$15,$1B,$11,$00
N DATA $11,$11,$19,$15,$13,$11,$11
P DATA $10,$10,$10,$1E,$11,$11,$1E,$00
R DATA $11,$12,$14,$1E,$11,$11,$1E,$00
S DATA $0E,$11,$01,$0E,$10,$11,$0E,$00
T DATA $04,$04,$04,$04,$04,$04,$1F,$00
U DATA $0E,$11,$11,$11,$11,$11,$11,$00
V DATA $04,$0A,$11,$11,$11,$11,$11,$00
' TRANSFORM TO FLIPPED FONT (S)
DO
READ (AA+CH),char
AA=AA+1
IF (char=0) THEN END
SEROUT 2,240,[noparse][[/noparse]CHAR] ' put into VFD
LOOP
RETURN
now another problem..
in this case when i choose an "S" i get the M on the VFD
but then i change the row : READ (AA+CH),char
to READ (AA+S),CHAR
i get my S
please help
Robban
Post Edited (Robban) : 2/19/2008 9:31:23 PM GMT
At the risk of sounding like I'm not being helpful, have you considered just using a rectangular mirror to reverse the image from the VFD? If necessary you can add reflecting prisms to change the angles any way you might need them. If you need lenses after the image is reversed, that is certainly doable as well.
This whole exercise seems rather tedious to me, unless there is some unknown reason for attempting to do this in software. Sometimes a software solution is the better or less expensive approach, other times it's a hardware solution that is more appropriate. In this case I'd choose a hardware solution, and that's not like me because I'm a programmer at heart!
Bruce Bates
Thomas Alva Edison
And i have not found any lenses that can flip the display.
wonder? is my programming correct ?
Robban
Didn’t you already have a thread on this where someone mentioned that there was no need to flip certain characters? It seems you are still trying to flip characters such as ‘A’ and ‘U’ which yield no change in output but do take up more memory.
What is prisms?
Robban
Due to your lack of space, I doubt a prism will help you. There is no kind of lens that will help either, but that's not due to the space problem.
IF you were able to use a prism, the reversion prism (Dove prism) would be the one to use. Here is how a Dove prism operates to reverse the image: http://en.wikipedia.org/wiki/Dove_prism
As far as prisms in general are concerned, take a look at this article: http://en.wikipedia.org/wiki/Prism_(optics)
Sorry about the space problem. Your present software approach may well be the best one in this case.
Bruce Bates
Thomas Alva Edison
