Yet Another Cut-Down Proto Board
hippy
Inspired by the Nano, Femto Stamp, other hacked at ProtoBoards and the PropGFX Lite Dip40, my own vision of a DIP carrier board. 40-pin DIP, 2.0" x 1.2". Suitable for connecting to strip-board etc using through hole Molex pins and SIL sockets.
With some track cutting and some link wires, one can have P0-P15 down the left, top to bottom.. These can be contiguous if Vss/Vdd above P8 can be disconnected allowing two holes to come off the top and added to the bottom. Enough real estate to fit a 3V3 regulator and TV-Out resistors maybe even an audio RC. So far, artist's impression only ...
Post Edited (hippy) : 2/12/2008 12:49:46 PM GMT
On what I said of Vdd/Vss -- I'm starting to think "P0-P7, Vdd, Vss, P8-P15, Vdd, Vss" on the left is actually more convenient, and less work.
The bottom horizontal row would work well for a Molex header, and if 0.1" sockets and another socket at the top row ( or for P7-P0 ), a strip-board with tracking top to bottom can piggy-back on top. That would allow otherwise N/C P16-P24 to drive interfaces on the piggy-back, TV, VGA, audio, even bit-banged serial or USB.
It's perhaps more flexible and useful than I thought for people like me who tend to build circuits to prove something or other then move onto another and want to re-use the Propeller Chip.
Cheers,
--fletch
UPDATE: Heh or you could use (external) pins 2 and 37 for stereo and build rc's between p2 and the left side and perhaps p0 or p1 on the right. Seems like it would minimize the number of jumpers you'd need
Post Edited (dfletch) : 2/13/2008 3:37:10 AM GMT
In retrospect, I think I like the idea of bringing it down to two rows with with a set of female pin headers on the
top and male on the bottom. Then create a small motherboard with audio/IO/etc for it to plug into.
Best of all worlds, small size, portability(can be dropped into other projects), and quick I/O connections. [noparse]:)[/noparse]
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook
Got an SD card? - PropDOS
A Living Propeller FAQ - The Propeller Wiki
(Got the Knowledge? Got a Moment? Add something today!)
@ OBC : I really like the beauty of the absolutely smallest square cut-out with 0.1" legs but a bit impractical for strip-board.
The nice thing about ProtoBoard cut-downs is that people can have whatever they want. It's really all about sowing the seeds of ideas.
--jazzed·... about·living in·http://en.wikipedia.org/wiki/Silicon_Valley
Traffic is slow at times, but Parallax orders·always get here fast 8)
I use a diamond coated cutting disk with my dremel to cut my protoboard·down to just big enough to put a row of right angle headers on all 4 sides and a header for the prop plug and a 2 pin·power supply header and I get a tight, flat·lil'·prop module·about 1.5" square.
This arrangement lets the board act as a module rather than a 'protoboard'. Any hardware·external to it, including device interface hardware is handled on another board that just plugs onto the prop-module.
It makes for a nice object oriented·system plugin.
I have a few prop sticks but I like this chopped 'module'·better and it's less expensive too.
Conversion takes about and hour but it's worth the time and effort. In fact, I wish they sold em that way. [noparse]:)[/noparse]
-Joe
Post Edited (JoMo) : 2/14/2008 3:55:01 AM GMT
