Parallax 433 MHz transmitter/reciver pakage
Just orderd Parallax 433 MHz transmitter/reciver pakage and i have read the datasheet for the LINX module that parallax use and what i can see there is very easy to modifye the module to transmitt upp to 3000 fett insted of 500+ feet.
![hop.gif](http://forums.parallax.com/images/smilies/hop.gif)
But before doing that check your local laws it may be illegal to send whit the maximum power in some countrys.
There is a lot more to an antenna than just the load. Antennas for various frequencies are ‘tuned’ by making them a specific length. This along with other considerations helps the antenna be more sensitive to frequencies the device uses. You can’t just take a bigger better antenna and put it on. It make actually work with less sensitivity if its tuned for some other frequency range.
Can i use them outdoors in -15C?
Well i will just test and se whats happends... [noparse]:)[/noparse]
