electromagnetic lock?
Not sure if I've asked this before but what components would be necessary to create a lock that opens electronically?· I'm picturing using the stamp to create the input to open the lock, but
not sure where to start?·
You might also look at the Nuts and Volts columns that you can download from the Resources tab on the main Parallax web page. Some of these discuss and give examples of the use of a keypad with a Stamp. You can also use an RFID reader. Go to the product page for Parallax's RFID reader and download the documentation to see how that works.
You find solenoid controlled striker plates
·there are diffrent type out there
Here is One type
http://www.bestaccess.com/index.asp?Mode=EAC_IDHMAX
Here is one more type
http://www.folgeradamedc.com/
But there not cheep
We have both type where i work
I like the second type better than the frist one because you have to put the wire in the door frame·and use a elec·wire type door hing·to the wall
I hope this help you good luck with your project
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 2/11/2008 4:56:07 PM GMT
There are a lot of cars that have locking solenoids for the trunk. A trip to a U-Pull-It junkyard should get you the parts you need on the cheap. You will need a relay to turn on the solenoid because the Stamp will not be able to drive it directly.
Daryl
