Conflict with GPS receiver and PSC?
I'm working on a project that involves both the parallax servo controller and the parallax GPS receiver. I just finished drafting the code and have begun testing it, but I keep running into a problem.
It seems that whenever I have the GPS receiver and the servo controller plugged in at the same time, the servo controller does not work.
What's weird is that, like all my other problems, this began to happen all of a sudden for no apparent reason. I've used both of them at the same time many times before this.
When I have the servo controller and the GPS receiver plugged in, I can power up the stamp and the PSC will automatically center all servos but I can easily move them with my hand, and apparently it is not sending any signals since the green LED does not blink (The red LED is lit). I also am unable to download programs when this is happening, since the Basic Stamp Editor is unable to detect the Stamp (it works fine if the power switch is set to 1, i.e. no power to servos/gps, and when the GPS receiver is not plugged in).
When I have just the servo controller plugged in, everything works as normal.
I'm using two programs to try and debug this problem, the following code is what I use to run the servos, and I've attached the program I'm trying to get to work in the post. In both programs, the PSC behaves as described above.
Any ideas as to what's wrong?
' {$STAMP BS2}
' {$PBASIC 2.5}
Sdat CON 12
baud CON 396
ServoPos1 VAR Word
ServoPos2 VAR Word
ServoPos3 VAR Word
CameraPos VAR Word
counter VAR Nib
DO
PAUSE 3000
ServoPos1 = 1250
SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", 5, 1, servoPos1.LOWBYTE, servoPos1.HIGHBYTE, CR]
ServoPos2 = 500
SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", 13, 1, servoPos2.LOWBYTE, servoPos2.HIGHBYTE, CR]
CameraPos = 300
SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", 12, 1, CameraPos.LOWBYTE, CameraPos.HIGHBYTE, CR]
PAUSE 500
ServoPos3 = 350
SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", 2, 1, servoPos3.LOWBYTE, servoPos3.HIGHBYTE, CR]
GOSUB Shutter_Button
PAUSE 2500
ServoPos3 = 1050
Shutter_Button:
CameraPos = 1250
PAUSE 1000
CameraPos = 300
RETURN
LOOP
END
Thanks Mike.
edit: btw, if this turns out to be the cause of the problem, do you still advise I run the same setup, as long as I change out batteries every so often, or is this harmful to the Stamp somehow?
How can I wire a battery back to the Stamp's power terminals?
Would I solder something like this http://www.radioshack.com/product/index.jsp?productId=2062219&cp=2032058.2032230.2032264&parentPage=family to the battery back wires and snap it on the Stamp?
I also noticed some people who had a battery pack with a cable that plugged right into the Stamp, but I am not sure what they are called/where to get them.
Mike Green is correct about the leads being reversed when the battery snap is taking the place of the battery.
If you wire it red to red and black to black, you will smoke the BOE.
Just a thought.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
