Garmin GPS Interface HELP
I am just getting into serial data transfer with the basic stamp. I have an Etrex Legend and I have the serial cable. If I have done my home work right then pin 3 on the GPS is data out and pin 4 is ground. I am wondering how to wire it to the stamp. Do I put pin 3 to the serin pin and the ground just to the ground on the stamp. Also any other good information on this that anybody has would be greatly appreciated.
Adam
Adam
This is both to protect the Stamp and the Etrex, which I believe is a 3.3v device.
I left the other data direction line unconnected, and I also didn't connect the 3.3v power.
Post Edited (Larry) : 2/10/2008 5:19:39 PM GMT
http://www.awce.com/rs1.htm
to convert to TTL should do the trick. I put together two of 'em a month ago, and am working on a Basic interface to the RS-232·telemetry output from a small rocket altimeter.
