Smoking an input pin on a BS2?
What is an input pin on a BS2 looking for?· Is it looking purely for 1-10mA of 5Vdc?·· What would happen if the pin was provided 12Vdc at only 2mA?· Would it smoke?
The reason I ask... is I·have a few Omron photoelectric switches that operate with 10-30Vdc.· The signal from·the Omron P.E. Switch is·also 10-30Vdc depending on the voltage·the switch is powered with.·· I plan to run the P.E.Switches with 12Vdc so the signal from the switch would likewise be 12 Volt DC.· I can·add about 6K·resistance to limit the current to 2mA from the P.E.Switch.... but am afraid the 12 volts is going to pop a pn junction inside the BS2.
I know it would be safe to·use the P.E.Switch's output to bias a NPN transistor to switch a 5 volt source to feed to the STAMP's input pin.... but was wondering what would happen if the BS2 was fed 12V at very low amperage.
Thanks for any assistance you can lend,
Marty - K4MLW
(and yeah.... this is my first microcontroller.... was it obvious?) <hahaha>
Post Edited (SCFalconry) : 2/10/2008 2:25:34 AM GMT
Marty - K4MLW
Does anyone have experience applying 24Vdc to a STAMP's Input pin? To limit the current to 1mA ....we could use 24000 ohms.
The reason I ask....I occasionally have access to discarded 24Vdc devices from my employer.
Marty
The protection diodes don't use their "reverse breakdown voltage". They're connected to conduct in a forward direction in overvoltage or undervoltage conditions. Download the PIC16F57 datasheet or the SX48 datasheet from Parallax and look at the diagram of the I/O port structure and you'll see them.
As long as you limit the current going into the chip, you should be ok. With static discharges, the problem you run into is the resistances and inductances of the chip's internal wiring are enough to get destructive voltages between adjacent points in the chip because of the very high voltages and sharp pulses involved.
In a way, you're not really applying 24Vdc to the Stamp's input pin. The protection diode is clamping the input voltage to 5.7V and the resistor is absorbing the remaining 18.3V.
Thanks again!· I'm off to look for the·datasheets now.
BTW... during my searches of past post in this forum... I've seen that JPG of you quite a bit.·
Thanks for all those other questions·that·you've answered for me as well.
Marty - K4MLW
I would put a 8 volt 1/4 watt zener in series with the stamp input pin along with a 220 ohm current limit resistor to protect the pin, just in case it becomes an output.
D. A. Wreski
