Newb Q: How can I clamp voltage at 9v?
Hello,
What I have is a variable 11-15 volt power source and I would like this source to run my BASIC Stamp board.
A while ago I thought I heard about a voltage clamping device that would regulate a higher voltage source to always output to 9 volts, but now I can't seem to find anything..
Could someone help me please? I suppose I could always use resistors to drop the voltage, but I thought there was a much cleaner and more accurate way to do this. I know the Stamp will run through a range of voltage, probably like 7-10 volts, so yes, I can use resistors, but again, that will waste current and if there is a better way to do this please let me know!
Thank you in advance,
BigMike
BigMike
Another option is to use a Zener diode. The Wikipedia has a good discussion of this: en.wikipedia.org/wiki/Zener_diode.
