Ping Pong Printer Project!
PingPongPrinter
The subject of a recent article in Nuts and Volts, the PingPongPrinter was inspired by the need to find a low-cost "ammo" source for the Ponginator our Ping Pong Ball shooting robot.
The resulting device uses a Prop-2 to power four servos, a gear head motor, three strings of LEDs, a CCFT light and a Serial Inkjet kit!
It was a lot of fun to make and produces a seemingly endless supply of Spherical Business Cards.
You can see a video of the device in action here:
http://www.youtube.com/watch?v=8Ep5OC3E02I
Or pick up the current issue of Nuts and Volts to read about it there. Here's some photos that I didn't use in the article as the article went to press before the unit was really done. [noparse]:)[/noparse]
http://picasaweb.google.com/VernGraner/PingPongPrinter
Let me know if you have any questions. [noparse]:)[/noparse]
Vern
PS: Some of you who also visit the EFX-TEK forums may find this post strangely familiar..
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're Senior Systems Engineer | obviously incompetent so why are we Texas Information Services | paying you? Of course,if the network http://www.txis.com | is up, then we obviously don't need Austin Office 512 328-8947 | you, so why are we paying you?" ©VLG
Nice printer, I would like one.
Don't know what I would use it for though, I have nothing to advertise.
Check out my robot using the propeller RECONAUTOR
If you like my avatar then check this out Propeller Domed Sticker
Nice work on the mechanics!
Great gimick for advertising.
James L
James L
Partner/Designer
Lil Brother LLC (SMT Assembly Services)
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
Kevin
Timothy D. Swieter
www.brilldea.com·- check out the uOLED-IOC, an I/O expansion for the uOLED-96-PROP
www.tdswieter.com
One little spark of imagination is all it takes for an idea to explode
The original ping pong printer shown at the top of this thread used a modified 5 gallon water jug to hold the blank ping pong balls that would gravity-feed into the printer. We discovered that this approach had some serious drawbacks:
- The ping pong balls have enough surface traction that they tend to bunch and resist being "agitated" by the rotating metal arms.
- This resistance to agitation caused the motor running the agitator to "pop" up off the top off the jug and twist, stressing the wiring loom and/or disconnecting the motor.
- The balls moving inside the plastic jug would build up enough static electricity to cause them to cling to the insides of the jug and not drop into the printer
These things combined to cause us to go in search of a new method of feeding the balls into the hopper. Rick Abbott created a new hopper with a chain drive "elevator" to scoop/lift/deposit the balls into the printer. We added an IR LED and an IR photo transistor to the trough so we can tell when a ball has passed on its way to the printer and stop the chain drive motor at that point. A picture of the updated hopper from one of our events is here:I'll get some better, up close shots along with some updated videos of the unit in operation soon. [noparse]:)[/noparse]
Vern
Post Edited (Vern) : 4/1/2008 8:23:15 PM GMT
