1.25V to 6V adjustable power supply
Power supply using the MAXIM MAX603CPA IC. Adjustable with two SMD potentiometers to 1.25-6.0Vdc. 500mA output current, easy voltage adjustment and stable output voltage once adjusted. Includes noise bypass capacitors for silent operation. Circuit is tested and working.
PCB layout / scheme attatched.
Are you have these boards for sale
··Thanks for any·
Sam
If you dont know how to make the boards,
·i guess I could make a couple for you -
ThanKs if you do not mind doing that for me
·Just let me know the cost for you to do·this for me
Could you·Please give ·a component list
·- but you would have to drill holes and buy and solder the components yourselves.
Yes i know· this i have all of this stuff i just do not make very good board my self
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 2/14/2008 5:15:41 PM GMT
