Execution time of multiple rdlong instructions
Reading 6 longs in assembly?
Is there a definitive amount of time the sequence
Will take? Is it 26 * 6 cycles ? (that would be kinda bad)
--Chuck
Post Edited (Chuck McManis) : 2/8/2008 4:25:24 AM GMT
mov r1, PAR RDLONG foo9, r1 add r1,#4 RDLONG foo1, r1 add r1,#4 RDLONG foo2, r1 add r1,#4 RDLONG foo3, r1 add r1,#4 RDLONG foo4, r1 add r1,#4 RDLONG foo5, r1 add r1,#4 RDLONG foo6, r1
--Chuck
In your case, it takes 6 x 16 plus from 7 to 22 clock cycles plus 4 clock cycles for the first MOV. That's 107 to 122 clock cycles.
If this is in a loop, you might be able to subtract the 4 clock cycles for the first MOV since it might be absorbed into the HUB synchronization time related to the previous HUB access.
Post Edited (Mike Green) : 2/8/2008 5:42:03 AM GMT
--Chuck
