question on PWM on Basic stamp
I am just getting started building a robot that will use a BS2. Here is my dilemma. I have two similar motors from two different model devices that I want to use as drive motors.
I am almost positive that they will not run at exactly the same speed under load.
I was thinking I could just add a pot to the faster motor to tune it to the correct speed. I assume the pot would waste power.
I think this would work OK, but was wondering, since the Stamp has PWM built in would it be a better way to go?
In the reference book I have they explain how to call the PWM routine but state that it will need to be refresehed to recharge the capacitor.
So in a normal drive the robot forward with both wheels turning (attempting to tune for same speed) would you suggest I use PWM on both motors, and change the duty cycle of the faster to slow it down?
I am thinking that I will be using a 754410 chip as a motor driver. I assume that the chip would get the PWM signal from the stamp, and pass it along to each motor with the correct duty cycle as it was recieved.
Am I on the right track or should I just put a pot in?
As you can tell I am not an electrical expert. My schooling is more towards the mechanical tilt.
Thanks for any advice.
Ted
Ted
