HB25 speed control
I am considering trying an HB25/12v system to replace what I currently use,· which is a 90vdc system using an off the shelf motor controller.· I just use the BS2 to switch the hi/lo speed controls on it,· which are two 5k pots.· I will need the stamp to read variable pots (or I could convert them to BCD signals) and then convert the reading·to the appropriate pulse width to run the motor at the desired speed.· This will be total redesign of an already working system (for cost reduction),· so I don't want to get too carried away with it before I know it can work.· The HB25 looks pretty simple so I don't really have any questions about that.· I'm just curious about reading resistance with a stamp.·
Don
