Propeller with more pins and other programming language
Hello
I'm new here and please informe me, exists a propeller chip with more pins?
a other programming language that isen't spin or asm, more like basic?
Regards
Satus
Regards
Satus
There is a 3rd party (ImageCraft) that will be releasing a C compiler for the Propeller in the next few weeks that will compile what is called "large memory model" code, a semi-interpreted assembly language that's only slightly slower than native assembly language.
There's a simple integer·Basic interpreter written in Spin (FemtoBasic) and several partially completed Forth compiler/interpreters.· There are several people working on a Java interpreter based on the Java used in the Javelin microprocessor.
I am 1010, so be surprised!
