Eagle Cad, SX28 and Components — Parallax Forums
DigitalDjDigitalDj Posts: 207
edited 2008-02-06 04:56 in General Discussion
Hello All,
I am having some trouble with Eagle Cad and finding the components I need for doing some schematics. First can't find the SX28 anywhere as well as resistors etc. I spent a little time just trying to find a simple resistor and no luck. Is there a easy way to find the components? I am using the search feature!
Also didn't parallax at one time sell a bare pcb for their deluxe breadboard?
Kevin
Post Edited (DigitalDj) : 2/5/2008 11:53:21 PM GMT
  • ZootZoot Posts: 2,227
    edited 2008-02-06 00:07
    SX libraries are available at the Eagle library downloads page -- but they are under UBICOM and SCENIX.
    Basic resistors are in the libarary catalogue "RCL" -- i.e. Resistors Capacitors Inductors.
  • DigitalDjDigitalDj Posts: 207
    edited 2008-02-06 00:18
    AH HA! Ok got it!
    Now how do I add the new libraries?
    Thanks Zoot!
    Kevin
    edited 2008-02-06 03:09
    I am NOT the world's greatest Eagle user -- but, once you've downloaded the new libraries to the appropriate Eagle folder (I'm not at that machine right now, I think it's called "lib" or "library" -- check the documentation), then, when in Eagle, you need to "use->"library"->"choose".
    Basically, as I understand it, the default built-in libraries are always loaded and ready-to-go -- additional libraries don't show up in a particular project unless you choose to "use" them -- otherwise your "working" library would be huuuuuuuugggggeeeee.
  • dkemppaidkemppai Posts: 315
    Zoot said...
    Whatch out for some of the SMD chip packs in those·libraries.·I found a·few that the packages were off a little. From what I remember the parts fit, but the sizes weren't 100% correct. Everything will work, but you'll find a very slight error when placing SMD parts.
    -Dan
    "A saint-like quantity of patience is a help, if this is unavailable, a salty vocabulary works nearly as well." - A. S. Weaver
