why does this error .map occur
when i tried to run a sample code in the sx programming window . it says .MAP file not found on disk . what does this actually mean
i ran the sample code Test1.src( which is from the manual )
any help would be greatly appreciated
What version of the IDE are you using? Also, can you post the code here? It's easier than me tracking it down, and then I can run it and tell you what is going on.
PeterM
