Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
EMF Detector.... — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
BASIC Stamp
EMF Detector....
Jed
107
2008-02-04 17:13
edited 2008-02-04 18:00
in
BASIC Stamp
What type of sensor would one need to detect EMF levels?
Mike Green
23,101
2008-02-04 17:31
edited 2008-02-04 17:31
What sort of EMF levels do you want to detect? The type of sensor you might use depends entirely on the kind of EMF you want to detect, the power, the frequency, etc.
Jed
107
2008-02-04 17:41
edited 2008-02-04 17:41
Power only. Say something that could detect high EMF levels around a house due to poor electrical wiring, etc.
Mike Green
23,101
2008-02-04 18:00
Start with the Wikipedia. Do a web search for "wiki EMF meter" and that will get you started.
The main types of magnetic field sensors are Hall effect and a loop antenna of some kind, often wrapped on a ferrite core or rod.
If you make your own, your main problem will be calibrating it. It's easy to detect 60Hz EMF.
Sign In
Register
to comment.
