Basic stamp 1 resonator
OK, I am building a stepper motor controller with the BS1. I Built the BS1 with OEM components. my problem is I am currently out of 4MHz resonators. So I use a NE555 timer circuit for the resonator. I am able to get this circuit to supply the interpreter chip with about 1MHz clock frequency, but cant establish a connection with the programing software. I was wondering if it is possable to establish a connection with the 1MHz clock or is it mandatory for a 4MHz clock frequency. I understand that there will be timing issues with this slower clock but all i wanted to do was quickly test my circuit for operation until I receive my new resonators?
To be perfectly honest, you're looking for nothing but trouble, IMHO. There are many PBASIC Stamp commands which directly or indirectly rely on the 4 MHz clock. Every one of the them that you use will have to be considered, in terms of the reduced timing impact, before you can use the command correctly.
Just by way of example (not that you're going to use it) the BS-1 Stamp is capable of asynchronous serial communication at a maximum of 2400 baud. Since 2400 / 4 = 600 you will only be able to communicate that way at a MAXIMUM of 600 baud. That goes back to the Dark Ages of communications! Other commands may be equally restricted.
Bruce Bates
There is no pleasure in having nothing to do;
the fun is in having lots to do, and not doing it!
Yes, I do understand all that is stated above. All i was trying to achieve was to see if my circuit was working, didn't care about the impact on the programing. as i have the proper resonator coming but they are a week out. I was just having problems with the basic stamp editor seeing it. And with the reduced baud rate that is probably the problem guess i will have to wait for the resonators.
Wait would it be possible to use a R/C network to achieve a 4 MHz clock? The 1MHz is about all I can get out of the 555 timer.
At the possible risk of being SHOT in the head with a sharply pointed DIODE ( --|>- ) <ouch>, would a FREE BS-1 Emulator keep you busy over the next week, until the 4MHz resonator comes in? If so, please be my guest at the link below. The program is provided by Al Williams, a long time friend of these Parallax Stamp forums:
http://www.awce.com/bs1emu.htm
Bruce Bates
It can't be just a PIC, it has to be a Parallax PIC, because it has the "tokenizer" programmed into it.
Thanks for all the help.
