PSC with Continuous Rotation Servos
I'm building a GPS-navigated robot using two continuous rotation servos as the drive system. They are pretty straightforward, but I do have one issue. Since the PSC centers all servos on power-up, the two continuous rotation servos move very slowly. My program doesn't start running until the GPS has acquired 4 or more satellites, so obviously I don't want them to be moving, so my question is how do I stop this from happening?
I ran a search and found this:
I bought my servos from Parallax so they do have this adjustable potentiometer, but this post only briefly touched this method. How exactly would I go about doing this?
Post Edited (skatj) : 2/4/2008 4:20:54 AM GMT
zoot said...
If your continuous rotation servos have a screw-adjustable pot for "tuning" the neutral point, that would be easiest. If you can not adjust the neutral/center point on the servo itself, you will need the host that is controlling the PSC to send your calibrated "neutral" pulsewidths upon startup.
- Stephen
