C4SX: Optional Patch For Better GUI Integration
Greetings-
If you are a user of C4SX (A C environment for the SX), you might be interested in a new patch that provides better linkage between the C compiler and the Notepad++ GUI.· This patch is available at http://www.rwsenser.com/c4sx/C4SXv03p02.zip.· With this patch in place, the C4SX environment and CC1B compiler can be conveniently run from within Notepadd++.· Once the ".src" output file is ready, the SX-KEY is then used as normal.
RW Senser
RW Senser
