StampWorks Experiment Kit SKU27297 (dimensions ?)
Hello,
I am considering purchasing 16(qty) StampWorks Experiment Kits (SKU27297) for classroom applications. I am wondering the dimensions of the board and if anyone else has ever considered mounting them in something like the enclosed. If anyone out there has suggestions it would be much apprecaited.
Thanks Glen
Post Edited (NSCC64) : 2/3/2008 4:46:14 PM GMT
Thanks Glen
Dave
Dave Andreae
Parallax Tech Support·
You might try using (the correct diameter of) this type of foot·instead,
http://www.surplussales.com/Rubber-Plastic/EquipBmprs-3.html
by applying your own adhesive to the top end of the foot (to glue to the PDB), and drilling a hole in your mounting board to receive the foot's retainer through the drilled hole. If you inserted a nylon bolt into the foot before you glue it to the PDB; then, you could pull (more easy than pushing?)·the foot's retainer through the mounting board hole by passing the bolt through the hole and pulling on it.
Google for availability of the right-sized foot.
PAR
